TMacie's avatar
TMacie
TT Hot skin issue
Hi All, I just picked up a 2007 Keystone Passport 285RLS and its got a habit of biting back. I'm seeing 110v on the outer metal structure pieces such as hinges and tracks.
I don't see anything as far as visible damage. The junction box where the shore cord connects to the "premise" wiring is good, nothing worn through there.
When I unplug from shore power, and disconnect the shore cable from the "premise" wiring junction box then test for continuity between hot and neutral with the main breaker off, there is none, as expected. If I flip the main breaker on, it shows continuity. I've seemed to narrow it down to the GFCI breaker. When the main breaker is on, and just the GFCI breaker is on. I get continuity between hot and neutral. I'm guessing there is a short somewhere in the GFCI circuit. Does anyone know if these had a common issue? The GFCI breaker doesn't trip when shore power is applied and all of the outlets work. Any thoughts?
Thanks,
Travis
  • RV professional repair. Don't plug in. Didn't you check all this before purchase? When you don't see it, time for a pro.
  • When they 'bit' like that, it's because there is no ground. Where the ground is failing could be anywhere. It could be a bad wire from the trailer to the electric plug, it could be the shore power connection itself, it could be a broken ground wire inside the camper. But when they "bite" like that ... it's almost always because the camper is not grounded.
