Hi all. We are renting a 35' tt in. Campground. There are only four piers underneath it. My wife is a heavy Walker. When she moves I can feel the tt move. Is this normal or does it need more piers. It...
I put a 40 footer on a permanent site. I addition to the stabilizers, I have three concrete block piers with wood shims on each side, and then I put a jack under each axle at the shackle near the wheel, (total four). This will keep the tires off the ground as each one loses air over time. I also have concrete block piers under the outside corners of the slides( two per slide)
