irontodd's avatar
irontodd
TT pre-wired for camera - system is junk (maybe)
Newer model Forest River, Shasta, and probably other brands of travel trailers have been outfitted with a backup/observation camera mount. Many dealers are saying this mount is for the Furrion branded cameras. My dealer included. the Furrion Observation camera WILL NOT FIT the installed bracket, nor will it mate up to the provided power lead, without some serious modification. I learned this the untimely way - luckily the box I got was a used item, and missing some parts, but the sales listing indicated new, so I was able to easily return it.
At this point, I contacted Shasta directly to be sure, so I didn't order another mis-fit. Here is their response:
forestriverinc.com wrote:
Thank you for contacting the Shasta Parts Department. The brand of back up camera for the mount is Way Interglobal. Their part number is CL-718W-C for the camera. Please let me know if I can assist further.
I found this camera on Way Interglobal's website, only in the store, not in the products section. Weird. Anyways, their store page (http://www.wayinterglobal.com/store/) has the camera ($329.90 as of May 2017). Ouch. Of course, I turned to Amazon to try to find a better deal. I was able to find what seemed to be the same system by searching for the part number alone , specified by the Shasta rep, "CL-718W-C". Turns out I see now that WAY now offers a digital model on their site, but that one is not available on Amazon by using the part number.
the matching product name that I found is
Elite CL-718W-C 7" Wireless Rearview System (TFT LCD (16:9) )
There were 2 options for this Camera - one sold by Amazon and one by another seller, but also on Amazon's site. The price difference was large. 125 dollars difference. Worried about getting an incomplete system I asked to the Amazon community "What's in the box?". I got a detailed reply in a day, and decided to also try to take the plunge on the less expensive one. I'm glad I did. It's a much better deal.
This is the box I received.
There's a couple of things that I'd like to share about my experience with the installation, so here we go. The product was packed pretty well by the manufacturer. Carved foam inside the box, and the monitor and camera were in their own foam bags. the Monitor had a clingy clear sheet over it as well for protection. The camera itself came with a universal mounting bracket with sun shield. Also in the box were the following:
  • Male to Male pigtail adapter (for camera connection to trailer)
  • 6 foot hard-wire power lead for camera
  • Monitor wiring harness
  • 12-volt plug in for monitor power
  • 2 different mounting brackets for monitor
  • Sun Shield for Monitor
  • Antenna for Monitor
  • Antenna for Camera
There's some work involved in getting the camera prepped to install to the RV-mounted bracket - you have to take off the bracket supplied with the camera.
There are 4 small phillips head screws that hold the Forest River supplied bracket to the camera housing. Keep track of those screws, you'll need them again to install the camera.
Below, I have the WAY camera on the left, and forest river bracket on the right.
Take the 2 phillips screws out of the side of the way camera/bracket. The antenna lead will still be connected to the bracket.
Using a small socket (my 4-way screwdriver had the perfect size), carefully remove the brass nut holding the antenna lead to the bracket.
I didn't get a picture of this next part, but I had to resize the holes in the plastic bracket part that came off my trailer. I used a 9/64 drill bit to make the holes a bit wider. The screws did dig into the plastic a bit at this size, so you could probably get away with using a 5/32 bit. To be clear, these are the two holes that are used to hold the camera to the bracket insert. Do not try to widen the 4 holes that hold the bracket insert to the trailer mounted bracket.
I then lined up the antenna lead with the smaller slit in the plastic bracket, and the power lead with the wider, center slot. I later found out (once I had everything installed, that this caused my image to be upside-down on the monitor. You may or may not have this issue. I simply turned the camera over in its bracket to resolve this.
and inserted the 2 screws to hold the camera to the bracket.
The antenna lead will get connected to the other part of the bracket. There's a little rubber stopper on the part of the mount still on the RV. Remove and discard. I intially tried install the nut and tooth washer back on the antenna lead, but found that I couldn't get the antenna on quite right. The knockout for the lead is kind-of D shaped, as is the lead itself, so I felt that I would be able to get things on tight enough that I don't have to worry.
Connect the camera to the power, you may find, as I did, that you need to use that male-to-male adapter that came with the kit. Screw one end onto the camera, and one end onto the rv side.
Remember those 4 little phillips screws? Use those to remount the camera and bracket to the rv
Now, I didn't take pictures of the actual install process of the monitor, but here it is mounted in our Jeep.
And here is a closer up shot of the screen itself in use.
Hopefully someone finds this useful.
  • You gave it a good shot. I've been wondering about these for a while now too. Thanks for takin one for the team and reporting back.
  • Well, the camera stopped connecting at all. I am sending it back!
  • Thanks RSD for sharing this info. I have confirmed on my trailer that the camera power is only on when the running lights are on. Other people might want to check their own situation.
  • One thing to check on your pre-wire is whether your camera is always on. Someone warned about that in another post. He actually installed a switch inside his trailer to turn it off when not on the road. I hope your extension works. I've never had a decent experience with wireless. But I haven't tried in a while. I've wired both my trailer and my tow vehicle, so I don't have to worry about reception.
  • Well, we are back from our first outing with the Way Interglobal camera in service. I will report here my experience of use.
    Fired up the jeep and turned on the headlights at home. Camera immediately connected. By the time I reached the end of my driveway, I got a message "no signal" showing on the monitor. As I turned, I had image, but as I straightened out, it went out again. As I worked my way through the plains towards the mountains, this behavior continued. I did notice that as vehicles passed me, or as I drove under bridges, the signal would flicker on momentarily. As I got into heavier tree cover the signal was slightly more reliable, although not consistently on. There were fewer periods of no signal, but still the greater portion was inoperable.
    When we arrived at the campground, I noticed that the antenna had swiveled, and was pointing downward. During some down time on Saturday I pulled the camera down off the back of the trailer, and did a couple things. I thought maybe I pinched the antenna cord when I flipped the camera in the mount. So I disassembled the camera itself to flip the circuitry inside the camera housing itself, and to get the antenna lead to route through its prescribed slot. In its proper orientation, the green LED is to the lower right of the lens as shown below, and the antenna cord properly aligns with the slot in the mounting bracket.
    I also realized upon reassembly that it's possible the antenna wasn't fully seated, but getting it seated properly was near impossible. I tightened the antenna the best I could, then added a drop of glue to the antenna where the spinning nut meets the body of the antenna. Once dry, I physically rotated the antenna to seat it. Once snug, the glue popped and I was able to realign the antenna to point upwards. Another drop of glue to hold it vertical.
    Everything seemed to be working well after this, at least while parked at our site. I was able to sit for about 10 minutes without the signal dropping.
    Even as we meandered out of the campground this morning, I had signal til we reached the open road. Once we were out of the trees cover, however, it was back to dropped signal except in traffic and under the bridges.
    When we got home and disconnected I did some additional diagnosis. I used a jumper to keep the trailer lights on when not hooked to the jeep. I turned the jeep around and pulled in facing the trailer. No issues with connectivity. Turned around again and had shoddy reception. I was able to drive 100 yards up the street and retain signal. That direction is uphill.
    I am thinking that the angle and path of the signal between the antennas is just not conducive to retain the connection. We have a metal sided trailer and a longish roofline on our TV (jeep Cherokee, vs say a single cab pickup). I just don't think things are strong enough to get a good connection.
    I have ordered a 9dBi antenna with a 3 foot extension cable to try to help with the signal loss. The antenna on the monitor side is just like the external antenna on your average Linksys wifi router, so a replacement was easy to find. Should be here before our next outing this coming weekend.
    I must admit I am not all that happy with this system right now. I was worried about the fact that it is wireless. That technology, in my opinion, is too flaky for a product that could be marketed as a safety product. My Camper is a short one too, an 18 foot box. I would hate to see how this camera would behave with a longer rig.
