carringb
Feb 12, 2019Explorer
bedpan wrote:
Thanks for the suggestion.....
I was thinking I could maybe use a piece of 1/2 stripping to provide support while retracted. Just need to remember to remove them prior to extending.. I will have a closer look on Friday..
Thanks!carringb wrote:
I carry some plastic carpenter's shims, and wedge them under the edge fo the slide floor if I need to use it while retracted. It mostly certainly flexes more than I'm comfortable with, without the wedges. The carpet conceals them, so you can't even tell other than it makes the slide floor stable.
With the plastic shims, the floor just slides off them then the end of the shim hits the carpet strips under the slide. It's so automatic, I don't even bother trying to remove them first.
