boosTT
Jun 25, 2018Explorer
TT Tipup Risk
My TT is about 4500 Lbs, 22' and tandem axle. When unhitched and without the stabilizer jacks down: how much weight is required behind the rear axle to lift the tounge? When I had a popup this was...
When unhitched and without the stabilizer jacks down: how much weight is required behind the rear axle to lift the tounge? When I had a popup this was a valid concern... it was quite easy to accidently lift the front of the camper with weight applied behind the rear axle. Is this not an issue with tandem axle trailers?
