MFL
Sep 15, 2020Nomad II
We don't have the trailer weight info, to determine the best choice for tires. The original spare was a C, tires now 3 D-rated, and now 1 E-rated.
If it came with Ds inflate them at 65 cold, before travel. Unless you want to replace three tires, and use all E-rated, which will give you more load capacity at 80 psi. You could just buy one new D tire, and use the E as the spare. IMO, running 3 Ds and 1 E, is not the best choice, even though the E with lowerd psi to 65 is about the same as D at 65. For best towing, all tires should match, tread design, size, wt rating, and number of plys.
Jerry
Jerry
44,068 PostsLatest Activity: Jun 09, 2026
