Well the problem is you have a 2500 Mega Cab 4X4 SRW with short bed......
GVWR is 10,000#
GCVWR is 25,300#
SO that would allow for a 15,300# trailer (GCVWR minus GVWR)
Unfortunately you only have a 1990# payload (GVWR minus base weight)
Base is 8006#
So IF you choose to stay within ratings.......not much of a 5th wheel
Pin Weight is typically 20% of 5vrs weight.
Your shipped weight of 12,100 plus 1500# cargo----13,600# at 20% is a pin weight 2720#.
That 2720# is what you have to carry -----payload
Your payload is listed at 1990# which you still have to subtract trucks cargo (passengers/stuff/5th wheel hitch) so 500# minimum drops your payload to 1490#
2720# pin weight minus available payload 1490# puts you 1210# OVER Payload
Also with 8006# base plus passengers/stuff 500# plus the pin weight 2720# puts truck weight at 11,226#------1226# OVER GVWR
Check the certification label/data stickers on YOUR door jam for GVWR/Base weight/Payload etc
One goes by ratings or justifies ignoring them
