MartiniSCP's avatar
MartiniSCP
TT Water Heater Question
Hello All.
Just trying to get to know our new rig better.
Attached is a pic of the water heater.
The lowest horizontal white tube/pipe is from the fresh water tank.
It goes past a valve to the bottom of the water heater.
There's a pipe from the top of the water heater, through another valve to the red pipe and out to the hot water side of the various faucets in the rig.
What I don't understand is why there is another pipe and valve between the hot water out and the cold water in.
Why would you want heated water to get into the cold side or cold water to get into the heated water pipe?
Also, I just discovered that that thing attached to the side of the water heater is probably an electric heater. When I turn it on I hear water start to simmer almost instantly inside the water tank.
But the lights in the TT dim when I turn it on.
I'm plugged into power from my garage. Probably a 20 amp fuse.
Thanks all.
Happy travels!
