Leland2 wrote:
In my case: I need a trailer I can back into a spot in Baja. I can't ''pull'' a trailer into the spot as I can't exit the truck forward. A door with access on the passenger side would be blocked by trees. Just can't have the door on the passenger side. Rear door could work -- driver side door, mid-trailer, would be ideal. Think Im striking out.
Is it a developed campground with a paved or concrete pad? If it is,
you could use something like
THIS.
Using a power dolly with a appropriately rated gen set should allow you to safely pull your trailer into the desired parking spot after disconnecting from your tow vehicle. This unit is expensive but probably less than a new trailer with a back door.
Good Luck.
ArizAl
