Leland2 wrote:
In my case: I need a trailer I can back into a spot in Baja. I can't ''pull'' a trailer into the spot as I can't exit the truck forward. A door with access on the passenger side would be blocked by trees. Just can't have the door on the passenger side. Rear door could work -- driver side door, mid-trailer, would be ideal. Think Im striking out.
If that spot in Baja is where you will permanently leave your TT then keep searching... it might work there but if you plan to camp anywhere else every other campground will be set up for doors on the right side. Sewer connections are always on the left ( driver's) side so not in your face.. If the camp site has a concrete slab, it is always on the curb (right)side also.
