NMace's avatar
NMace
Tune Up
I have not done a DIY tune-up since the days of points and condensors.
I have a 2002 Chevy Silverado 6 liter with 110,000 miles and believe it time.
Besides replacing the spark plugs, checking the wires, and cleaning the K & N air filter, is there anything else I need do?
Unlike some trucks I have heard about, the plugs seem accessible without special tools, are they?
You guys have always been great, thanks in advance,
Neil
  • That's pretty much it. And yes, it's easy, no special tools. Change your serpentine belt(s). Change your transmission fluid too (every 50k), but use Dex VI, not the Dex III that the '02s called for. Dex VI is backward comparable and is a synthetic blend, run much cooler. If you have 4WD, change your transfer case fluid (also every 50k), and front and rear differential fluid (every 30k).
  • Perhaps replace the fuel filter and 02 sensors (check manual).
