Richard65's avatar
Richard65
Turbo diesel engine sizing?
I presently own a 4000 pound 18 foot RV and pull it with a gasoline fueled, normally aspirated, truck rated to pull a 6000 pound trailer. However, when towing at 10,000 feet altitude, up a mountain, the truck will only make 30 MPH. I consider the truck grossly under powered and would purchase a more powerful tow vehicle if I was to replace the present truck. I would buy a gasoline, normally aspirated truck with a tow rating of TWICE my planned trailer GVWR to get good uphill, high altitude performance. Lesson is: The gasoline, normally aspirated tow vehicle's posted tow rating is not useful at high altitudes.
I am planning to buy a new larger trailer, GVWR of 15,450 pounds. I am planning to buy a Dodge Ram 2500 Cummins turbo diesel truck to pull the trailer. What should be the published maximum towing capacity of the turbo diesel truck to get good performance at say 10,000 feet, uphill, or into a head wind at altitude?
Does anyone out there have personal experience with a 2014 Dodge RAM 2500 Cummins diesel with a
I am proposing a 2014 Ram 2500 Cummins with Exhaust Engine Brake, 6 speed auto transmission, 3.42 differential with rated tow capacity of 17,100 lbs. My trailer weight is 15,400 pounds. What is your opinion of the capability of the truck to pull at say 10,000 ft in the mountains?
Does anyone out there have personal experience with a 2014 Dodge RAM 2500 Cummins diesel with a stock 3.42 differential pulling a 16,000 lbs. +/- trailer over 10,000ft. mountain passes?
