AnEv942
Jun 17, 2013Nomad
Wouldnt swapping the arms make it worse? ears would be pointing at the fenders. Or is suggestion actually the frame mounts themselves.
The eyebolt might, if it gives you enough clearance work-thru the ear of stingers...cheap enough to try- 1/2" eyebolt with enough shank to nut & bolt both sides of ear. If it worked Id be tempted to replace with lifting lugs if shoulder spacing close.
My self I would redrill hole in arms-if you have welder or know someone or good shop easy enough to extend using a piece of 1 1/4" inside for back up. At least my arms are 1 1/2" x .120 wall.
Nice rig-looked at site 'cause I couldnt see the front arm- but this picture show better the relationship fender/TL
http://farm3.staticflickr.com/2826/9060758173_477a809652_o.jpg
