bobndot
Nov 13, 2015Explorer III
I would be more concerned with the mounting of any tv you choose.
I have seen broken TV's on rv floors , especially in TT (with no shocks) traveling through cities with rough roads.
I installed a removable mount . If you choose to do that, you can use shorter screws because your NOT traveling with the weight of the tv on the mount.
The one I bought has 2 bases for the LR and BR areas, I use one tv and switch locations when needed.
When I travel, I simply remove the tv and place it on the bed where its safe and cushioned. I secure it with a ratchet strap that I slip under the mattress platform.(the strap remains there tucked away when not in use)
There are a few different removable mounts on the market, some are single,this one is double. The arm just slides down from the top and clicks into place. Unclick and lift to remove. The arm remains on the tv.
Ready America 3500 removable tv mount .
http://www.rvautoparts.com/Ready-America-TV-Wall-Mount-MRV-3500_p_12885.html?gclid=CJrkqZzAjckCFYM6gQodke0N9A
