RooGuy wrote:
Thanks for the quick replies.
Do I connect the antenna cable to the TT's cable tv connection or do something else?
If you have an amplifier in series with an existing antenna, you would probably wish to use that connection for your new permanent antenna. Connectivity depends only on getting the signal from the antenna to the television. There's no wrong way to do it.
When using a home made antenna or a purchased antenna with no wiring, you should make sure that impedances are matched. That is easily accomplished by using a balun from the antenna.
