jhocksrule's avatar
jhocksrule
TV Antenna rotated
I have a winguard TV antenna. Over the weekend I cranked up the antenna and while I was cranking it inside the handle and the spring and and the twisting knob (the part that rotates the anteanna inside) fell out. I was able to raise and lower the antenna inside using a nutdriver. Apparently when I did that the antenna itself rotated on top of the camper. Now I can't get the antenna to rotate back to the proper position to where it lowers down into the cradle that holds it when it is down. Any help would be appreciated!!!!
  • You should be able to raise the antenna back up then turn it to the proper position then lower it again. Is there a part actually broken or did the set screw in the handle just come loose? I've had mine come off and it pretty easy to put it back together unless a part is broken.
