I have the typical crank-up rotatable “T” shaped antenna you see in the TT camp grounds. I believe they are made by Winegaurd. In 6 different camp grounds near major cities, we have only been able...
On a side note, be sure to turn off the booster when you lower the antenna as if your next site has cable, the cable tv will not work with the booster on.
