rbpru
Feb 26, 2014Explorer II
TV antenna,
I have the typical crank-up rotatable “T” shaped antenna you see in the TT camp grounds. I believe they are made by Winegaurd. In 6 different camp grounds near major cities, we have only been able...
SCVJeff wrote:Lynnmor wrote:The ONLY thing it does is shut the amplifier off. Depending on where you are and what you can pickup, the Wingman can make the difference between no TV at all, and several reasonably good channels.enblethen wrote:
Thanks for the update!
Now you can look into the Wingman. It made a big difference on our over the air. Nearly as mush as turning on the antenna amplifier.
The antenna amplifier switch does more than turn on the power to the amplifier. The switch also connects and disconnects the antenna cable.
I installed a Wingman and found just a small improvement. You must be more precise in pointing the antenna with the Wingman.
