X2 on all above.
1.Make sure booster is turned on.
2, Raise and turn your antenna to face the direction of the nearest town that broadcasts your local stations.
3. Go to menu, antenna, and scan channels on your TV.
4. You will have to rescan the TV for channels at each CG you go to.
5. If the channels are digitized going in and out, slowly turn your antenna to fine tune the direction.
When you get on the road RV'ing, when you pull into a CG 'look' which 'direction' everyone's antenna's are pointed.
THAT will save you the time of inching your antenna around for minutes on end looking for the correct direction, your fellow campers have done the work for you!. :W
