ijon's avatar
ijon
tv antenna
I have a 2005 Lance truck camper 1010. It has a crank-up dish with a round tv antenna bolted to it. I have not used the tv antenna since the analog to digital changeover. I tried useing it with a new tv and can't get any channels. Could it be the tv antenna?
    The cables corrode. Check the cable ends to make sure they are in good working condition. Our 2005 lance with the same set up works fine with new TVs. I have had to crimp on a new connector that goes into the round TV Antennea. Also make sure that the Green light is in the ON position so that the Amplified antennea is getting power. That does make a difference.
    On the TV make sure that you do a channel scan with the "OverAir" choice selected. They are preset from the factory to be in the "CABLE" choice..
44,050 PostsLatest Activity: Sep 08, 2025
