Every TV SET I have ever seen has a standard four holes arrangement on the back of them.
You should be able to go to WALMART or any big store and find something that might help you come up with a wall mount that will work for you. There are many versions available all using the standard four hole mounting scheme...
This is a typical HDTV swivel wall mount using the four screw pattern on the rear wall mounting scheme...
Google image
Also note that depending on the age of your HDTV SET it may not be compatible anymore with the HDTV digital TV signals that is being transmitted over the airways these days. Even some cable hookups at the camp ground cable connections are now converted over to the somewhat new digital TV format... You might want to make sure your present TV set is working first with the available HDTV signals as you may want to purchase a new HDTV for your trailer that may require a different mounting scheme to work for you...
Roy Ken
