ymeyer62's avatar
ymeyer62
tv hook up
Hi
I have a 2014 JAYCO jay feather lite. I have purchased a new tv and cant figure out how to hook it up. Any help would be greatly appreciated. ( I couldn't see anything in my owners manual)
YVONNE
  • RoyB's avatar
    RoyB
    Explorer III
    My trailer has a outside CABLE HOOKUP point. I plug MY TV into the Antenna Panel on the inside usually right next to where your TV sits. The Antenna Wall Plate has a push button on it. If the small LED light is 'ON' push the button to turn it 'OFF' so you can see what is coming in from the CABLE outside protection. When the small light in 'ON' you can raise your roof BATWING antenna and scan for local BROADCAST TV signals from the local towns Over the Air...
    The bedroom TV connection will be slaved off the Antenna Wall Panel as well... Same deal LED 'OFF' to watch CABLE TV or 'ON' to watch roof mounted BATWING antenna TV signals. You have to go to the digital TV menu and select either CABLE or ANTENNA and scan for channels just like you do from home everytime you setup for camping...
    This is what the Antenna Panel looks like from google image search...
    Of course trailers are all different but this is pretty much the basic method...
    Roy Ken
  • ymeyer62 wrote:
    Hi
    I have a 2014 JAYCO jay feather lite. I have purchased anew tv and cant figure out how to hook it up. Any help would be greatly appreciated. ( I couldn't see anything in my owners manual)
    YVONNE
    You should have been given a full walk thru by the dealership BEFORE you accepted delivery of it.
    If they didn't give you one go back and schedule one. They show you how to use 'everything' on your TT. It's standard operating procedure by the dealership when you buy an RV.
    Take a video camera with you and tape it all. It's a lot of info to digest at one time! Good Luck with your new RV. :C
  • Hook it to what? Roof top antenna? Get a short piece of coax cable and connect it to antenna in on the back of the TV. The other engd goes to the powered antenna port. Raise the antenna turn on the amplifier and start searching for q signal
