dl68camper's avatar
dl68camper
TV Mount help
I would like to add a TV Mount to the inside wall of the bedroom slideout and the outside under the awning of our TT. I would like to leave it mounted in the bedroom during towing. The TV is less than 15 LBS. Has anyone safely done this? I was thinking of using pop rivits to attach the brackets. This particular mount is perfect (2 bases, 1 arm) Is this foolish or if done correctly will it last forever?
Thank you,
David
2015 Cruiser Radiance 28RLSS
  • If it is laminated wall, you don't really have studs. The manufacturer laminates mounting plates into the wall where things are to be mounted.
    If an interior wall (not inside of an exterior wall)! you can sandwich a larger section of the wall with plates of heavier material, like plywood or 1/8" aluminum, and bolt through the sandwich. Even so, with enough load, there is a risk of the wall failing around the edges of the sandwich.
    We tend to think in terms of house construction, since we use these RVs like houses, but they are really more similar to corrogated boxes, lightweigth walls getting strength from bond of skin to the core, the core in this case being foam insulating board and the skin usually a very thin wood veneer or composite sheet. Where there is no mounting plate laminated in place of insulation, there is nothing in the wall to hold a fastener.
  • I went back and looked at the brochures for your trailer and they really don't mention wall construction. The weight listed for your size trailer would lead me to believe that it has aluminum studs not wood so with the right sized rivets you may be OK if you can get into the studs. I would be very hesitant to mount a TV just to the wall without anchoring directly into the studs regardless or wood or aluminum. I still say talk to the dealer, they have been asked this question before and may have an easy answer for you.
  • 2012Coleman wrote:
    Lots of people use the idea Westend mentions. You can also use a stud finde to fint the stud and mount the bracket. I used small lag screws. I also have a 23" flatscreen that travels well while mounted. Whatever you do, don't mount anything using pop rivets.
    I don't know what to make of your suggestions. Stud finder is pretty much useless in a camper with plywood walls and fiberglass exterior and I've used pop rivits hundreds of times. Camper manufacturers use them all the time. I don't know yet if they would work in this application and yes it would be ideal to drive lags into studs but finding them could be difficult and I'm unsure of the thickness in both locations.
  • FrankShore wrote:
    I would find out from your RV dealer where exactly to mount the articulating arm. Also, I'd go for a arm that locked into place.
    I've contacted both the selling dealer and manufacturer but haven't been able to get to the right people yet. I'll keep trying, but in the mean time I was hoping to get some feedback from this community. The link I posted is for an adjustable locking mount.
  • camperforlife wrote:
    There are thousands of trailers out there with TVs mounted ready to travel and have done so safely for tens of thousands of miles. The important part is to make sure that your TV mount is fastened to a wall that was meant to mount a TV. They usually have a sticker on the wall that says "TV mount location" or something similar. If you don't have an obvious mounting location, talk to your dealer to see if there is one, most bedrooms do.
    I appreciate the reply, but I'm trying specifically to mount in locations not tagged for a TV. Hence the reason for my post.
  • Lots of people use the idea Westend mentions. You can also use a stud finde to fint the stud and mount the bracket. I used small lag screws. I also have a 23" flatscreen that travels well while mounted. Whatever you do, don't mount anything using pop rivets.
  • I would find out from your RV dealer where exactly to mount the articulating arm. Also, I'd go for a arm that locked into place.
  • I use one of those articulating arm mounts. I mounted the bracket to a plywood backer board and mounted the backer through the paneling, into the studs. Since I have a 32" screen, I was able to span three studs and the backer board is behind the screen.
  • There are thousands of trailers out there with TVs mounted ready to travel and have done so safely for tens of thousands of miles. The important part is to make sure that your TV mount is fastened to a wall that was meant to mount a TV. They usually have a sticker on the wall that says "TV mount location" or something similar. If you don't have an obvious mounting location, talk to your dealer to see if there is one, most bedrooms do.
44,070 PostsLatest Activity: Jul 21, 2026
