CraigGe's avatar
CraigGe
TV mount on pivot wall
TV=television
We recently purchased a new trailer that has a pivoting TV wall in between the master and the living space.
Layout
The back of this wall area is 1/8" ply. There is a solid piece of something running vertically at the mid-point that is about 4" wide and not much thicker than the ply backer. The whole inside is covered in a felt cloth making it difficult to see what the center support is.
I'm trying to figure out:
1) What is this solid material in the center? Metal, wood, plastic?
2) Is the plan to anchor only to the solid material in the center?
3) Should I be anchoring a piece of 1/2" ply to the center bracket, and then mount the TV?
4) If I just mount to the center bracket, would I then expect to have exposed bolts and nuts on the opposite side of the wall, or is there a trick to avoid that?
I am handy and willing to go to town on this thing if necessary, but would much rather cheat here. None of this is addressed in the manual, so I'm hoping one of you might have a similar setup.
Thanks for any advice.
  • Finally found some time to work on this. I started off by calling Heartland and got a real nice guy that spent half of his day tracking down the schematics and relaying the pertinent information to me. In fact, it's worth saying that every time I've called Heartland pre-sales and post they've been extremely helpful. Granted, I wasn't asking them to replace a bad part, but I expect that exchange to go just as smooth if the scenario arises.
    Anyhow, the center support in these pivoting walls is a 3/4" thick by 4" wide slice of ply-"wood". I bought some 1" lag bolts, and a couple of washers to keep it from popping out the other end of the 3/4" material (even though I managed to do it with the drill anyhow... twice). Mounted the bracket (http://www.amazon.com/VideoSecu-Bracket-Monitor-200x100mm-ML206B/dp/B001SDBVCE), bought a super lite TV (http://www.amazon.com/gp/product/B0074FGNJ6), and so-far-so-good.
