Glowrdr
May 04, 2018Explorer
TV Mount Questions
So I finally took delivery of my Salem 27RKSS this week, and have a few things needed to get it ready for our trip next weekend.
I've been reading about mounting TV's, and it all seems pretty straight forward. Find the sticker, check for backer, and mount.
My main question, is this one is set up for a 42" TV in the living room, and I will mount a smaller one in the bedroom. I have not attempted to peek inside of the walls to see what kind of backer is actually used in my trailer (I've heard anything from 1/4" to 2" thickness). Is there a standard for a weight I should be trying to stay under? I will be going LCD to help with that aspect, but mounting a 19" TV is quite a bit different then a 42" if we are talking about 1/4" thick walls.
Do I just trust the manufacturer and mount away? Should I install my own backer board (not even sure how you would even get 'into' the walls to do this), or should I consider mounting an external backer to the actual studs in the walls? I just don't want to mess something up in my new camper!
As long as I'm asking - whats the general rule for traveling? TV's removed? I was planning on getting locking mounts - but would like to leave the TV mounted if possible.
Thanks for you help, and here's a picture! By the way, when did they do away with the whole model number/length correlation? My old camper was a 24RB (and actually 24 feet). This one I thought was 3 feet longer... boy was I wrong. Its actually 12 feet longer and now won't fit in my designated parking spot I had.
