Just to close out this discussion here's what I did: I cut and stained a piece of 3/4" oak 5" wide and long enough to span from the ceiling to the top of the wardrobe cabinet. I put two sheet metal screws into the aluminum tube frame at the top and two pocket screws downward into the cabinet top at the bottom. The TV mount I used has a removable plate that stays attached to the TV which I secured to the mount with two thumb screws. I sandwich the 7.5 lb, 24" TV between two pillows while traveling. I found the full motion mount on Amazon for $13. Thanks for all the input.
