Just curious what everyone else does with their rear TV tires when towing? Do you bring the inflation up to tire max or keep at recommended level for vehicle?
2011 RAM Dually 45 rear solo and 60 loaded. Pressures based on load. Use inflation/weight chart for your tires and add 5psi. Even wear. Too much air in rear tires will result in the centers wearing pre maturely and less stopping traction. Also too much air in rear will give harsh ride.
