Just curious what everyone else does with their rear TV tires when towing? Do you bring the inflation up to tire max or keep at recommended level for vehicle?
I just replaced the original equipment junk tires with bf Goodrich at kos, and found they rode rough at 70 pounds. Unloaded I put 50 in front and 45 in the rear. The 2013 ram has a low pressure switch to allow lower pressures. The dash light comes on at exactly 43 pounds.
At 55 psi in the rear, the tires cause a harsh ride....when towing I run 60 psi and all is comfy...
