NYCgrrl
Jan 19, 2017Explorer
TV suggestions
Got a call from the manufacturer and thus made a final decision: we'll be getting a wet bathroom retractable roof Alto 1723 R: http://www.safaricondo.com/pdf/caracteristiques_alto_en.pdf Now come...
camp-n-family wrote:
Have you changed your mind on which tt? Something with a dry weight of 4K will put the loaded weight out of range of all the midsize SUVs. That kind of weight will require a 1/2 ton truck or full size SUV. If you want to stay with a midsize SUV you need to be thinking a loaded weight of less than 4K
As for FWD or 4WD, doesn't really matter when towing on road. 4WD will be a want if you do a lot of off road towing or driving in snowy climates. Most of the midsize SUVs are based on car platforms and have AWD (all wheel drive) which is a bit different again. They are essentially 2WD most of the time but will automatically send power to the other wheel when slipping is detected. 4WD vehicles are usually not full time 4WD. They are usually RWD and have to be manually selected to 4WD when wanted and is not good for highway speeds or on dry pavement.
