DD716TED wrote:
The_real_wild1 wrote:
What are your tires inflated to? Recommended Psi doesn't tell me much. But as mentioned I would run them at 40-50 psi. Is the truck lifted or levelled? That will hurt the ride also.
I run the tires at 75 psi (front and rear) as the label on the door post says.. I tow a 26ft tt about once a month.. should I lower pressure while not towing or???   truck is not lifted or height altered.. factory stock
Drop them down to 40-50 psi. Depending on how heavy your trailer is you can bump them up for towing. Even dropping them down 20 psi will make a huge difference in ride. 75 psi is way too high for driving unloaded.
