Me Again wrote:
DD716TED wrote:
Me Again wrote:
You sure the Wild County tires were not LRD vs LRE? Chris
My mistake... they were Wildcat Radial A/T
Same question, were the old tires LRD and new ones LRE. I had Les Schwab snow tires for my earlier RAM that were LRD and they had a noticeable better ride than the LRE's. Have you checked inflation? An empty truck does not need 80 PSI in the rear tires. Try 44 lbs. Chris
Bad advice... Don't ever run 44lbs in a Super Duty.  That is way too low.
I prefer to run 65PSI for good tire life, fuel economy and is the tire pressure recommended.
