DD716TED wrote:
I checked and my front springs are coded WWFF which is normal (no snowplow).. The only thing I have yet to try is lower the PSI of the tires.. Door post says 75 PSI which is where they are at (Load Range E tire).. How low do I dare go to to see if that helps without damaging the tires or impacting saftey? Maybe new tires are what I should ask Santa for as my previous 2002 F-250 SD never rode like this one..
It's not the tires! Lower the pressure. You asked and have been advised many times on this. As well as pressures to start at, what others are running, links to inflation charts, etc.
