The_real_wild1 wrote:
DD716TED wrote:
I checked and my front springs are coded WWFF which is normal (no snowplow).. The only thing I have yet to try is lower the PSI of the tires.. Door post says 75 PSI which is where they are at (Load Range E tire).. How low do I dare go to to see if that helps without damaging the tires or impacting saftey? Maybe new tires are what I should ask Santa for as my previous 2002 F-250 SD never rode like this one..
Just go lower the pressures to 50 psi. Drive the truck and report back.
Put the fronts at 60 and rears at 45 and take a test drive. Chris
