Me Again wrote:
DD716TED wrote:
Set front at 55 psi rear at 65 psi rides like a new truck.. will fill all tires to recommended 75 psi when towing thanks to all
Took quite awhile to get you to come around. I would go up a bit in the fronts and down more in the rears, as I suggested above. Front do not need to be adjusted up and down, load varies little on front axle. Chris
Merry Christmas BTW
This!
Or....set all 4 corners at 60PSI when not towing and be done with it.
Then come towing season/time and just raise the rears. As Chris stated, load on the front is basically static.
