We have a F150 TV, 27' TT total weight around 7600lbs. Reese DC anti-sway WD system. all of my weights are good after I have been over the scales. My max trailer weight for the pickup is 8000#. The tr...
As a rule bigger is better because you have more capacity to spare, particularly on your max cargo capacity.
Most TVs can pull a lot more then they can carry. I think you will find your loaded for the trip tongue weight is at least 800 or 900 lbs. That does not leave a lot for people and gear.
Check the change in truck weight with and without the trailer and see how much cargo capacity you have left.
