SDcampowneroper
Oct 30, 2020Explorer
schlep1967 wrote:THIS
Fill your onboard water tank and disconnect the hose. If you trickle the faucets the grey water tank will fill up within a few hours and flood the camper.
Everything else sounds fine.
Trickling water is the worst thing you can do. It will ( maybe ) keep your fresh hose and in house lines from freezing, but what about your 3" stinky slinky ? The very slow trickle through it will freeze, turning it into a 3" poopsickle which will back up into your grey tank, then flood the rig! NEVER TRICKLE an RV . Unless you also have an heated insulated waste hose connected to a sewer line that is below the frost line so it wont freeze , then back up anyway.
Not to mention the waste of water to save you a little inconvenience.
Do yourself service. Learn to winterize in a few minutes with a little pink A/F , compressed air or whatever works for you.
You save money A gallon of pink is a lot cheaper than the power and propane to heat it for one night
44,071 PostsLatest Activity: Aug 30, 2026
