jerem0621
Nov 07, 2020Explorer II
Ensure water tank is off, drained, and bypassed. Open low point drains, blow out the lines, close the low point drains and blow out the rest of the lines moving from the furthest faucet to the water inlet to the closest. Drain the gray water tank and the black water tank if needed . Use $2.50 gallon of RV antifreeze and run through your lines. Add pink stuff to all the s traps.
The first time should take you 30 min to 1.5 hours. After that it gets much quicker after this.
Takes me 20-30 minutes now because my Zinger has a dumb false mini wall I have to crawl into a storage cubby and remove before I can bypass the water heater.
I do not mess around with freezing temps. Frozen lines are no fun and I have had to fight them enough. I just winterize as needed.
Thanks and good luck.
Thanks!
Jeremiah
Thanks!
Jeremiah
44,071 PostsLatest Activity: Aug 30, 2026
