davehultin's avatar
davehultin
Explorer III
Jul 05, 2022
Two tires: A tough decsion
Yesterday we returned from our most recent trip, and seven miles into the trip ... kapow! Blowout. :-(
I'm at the point where I want to get fresh tires all the way around before our long trip at the end of the month, but I can't quite decide which tires I should get.
The trailer's GVWR is 7660. The tires are 205/75R14.
The original tires are Kendo Karriers, rated to 2200 pounds at 75 psi.
It seems like the big favorite around these parts is the Goodyear Endurance, but they're rated at 2040 pounds at 65 psi.
Both are load range D, both are 8-ply, so it seems the most significant difference comes down to the load capacity.
Pros and Cons:
* Pro for Karrier: Higher load capacity.
* Pro for Endurance: Seems to be a favorite of many.
* Con for Karrier: I've alraedy replaced two prior to yesterday's blowout. Confidence in Karrier is declining.
* Con for Endurance: I'm giving up some load capacity if I replace all four.
So ... do I get the "better" tire and sacrifice some carrying capacity?
Or, any other tire suggestions? (etrailer.com shows Westlake as another option, which I've never heard of.)
  • The Carlisle HDs are one of the best out there right now. Had them on our TT. I would go with the load range E if they are available in your size.
  • Get 215s for more capacity unless they won’t fit. Likely they will.
  • I assume the trailer has four tires and the Endurance will cover the full GVWR of the trailer. 7660 vs 8160
    The extra rating of the Kendo does not seem to be helping. Quality of the GY is unmatched lately.
    This would be an easy decision for me.
