dougmarrs's avatar
dougmarrs
Two Vehicle Transmission
I have a 2000 Chev 1500 LS - 4.8 engine with automatic transmission and 263,000 miles on it - I tow a Jayco Ultralite that weights around 5000 lbs loaded. plus load in truck - Weights are under so I am not worried there but when towing I use tow haul mode and run around 60-65 MPH at 2500 RPM - mileage around 9 - 10 MPG - Should I look at replacing the older transmission with a newer 6 speed one? Will this lower my RPMs and help on gas mileage or just rebuild the original tranny?
  • What is wrong with the present tranny that makes you contemplate rebuilding/trading?
