Hemling
Jul 27, 2021Explorer
Ultimate payload monster?
What do you think is the top payload rating among new one-ton trucks? All the advertising goes toward horsepower/torque and towing capacity, but what configuration is king of payload?
rjstractor wrote:JRScooby wrote:
I ain't much smarter than a box of rocks, but I would guess there might be other components that limit GWR?
BTW, I don't think I have ever seen a weight tag where the total of axle weights is not greater than GVWR.
On a pickup you won't see that but on commercial trucks you likely will. My former motorhome, a 1998 E450 based C had a RGAWR of 9450 and a FGAWR of 4600 and a GVWR of..... 14050. Those axle weight ratings are lower than those of a 350/3500 series dually pickup yet the GVWR is just over 14K, probably to put it into the class 4 truck group and reduce the emission requirements. Fast forward to today. The new E450 has axles of 9600/5000 and a GVWR of 14500, again lower axle ratings than a new F450 dually, which can be as high as 9900/6000. Yet the GVWR of said truck is only 14000. If this isn't evidence of the OEMs artificially lowering GVWRs of pickup trucks to keep them in a given DOT weight class, I can't imagine what is. If Ford used the same criteria for the F450 pickup (not cab and chassis) as the E450 cutaway its GVWR would be 15,500 or more.
