toddb's avatar
toddb
umbilical hardwire
I'm a new owner of a 2010 AF 992. I've been fixing up little things on it and the umbilical is a hodgepodge of parts.
What is the point of disconnecting it from the camper? I was just going to hard wire a new 7 pin using a trailer box. I don't see any clearance issues loading since it would stick out as far as the current plug.
Thanks
Todd
  • ^ interesting. Pretty sure mine is charging but I've never checked it. I do have a backup camera wired to the reverse wire, maybe that's enough for it to detect.
  • On the 2017 model Fords on, however, you do not have an active charge lead unless the module detects a trailer brake in the circuit, which is kind of a bummer! I wish they would stop trying to solve problems no one is having!
    https://fordbbas.com/non-html/Q-263_Trailer_Tow_02212017.pdf
  • Some tow vehicles do not shut off the charge line to the trailer. Disconnecting the umbilical cord prevents the trailer from discharging the tow vehicles battery.
    Fords for example has a relay that disconnects the 12 volt charge line to the trailer.
    Other vehicles that do not disconnect charge line can be easily changed by installing a relay operated from a "hot" in run position control circuit.
