devildog1971's avatar
devildog1971
unable to find tie downs for 3500
I found a low milage 2007 G M C crew cab sierra 3500 long bed I have decided to buy either a Northern Lite or Bigfoot las night I went to Torklift's website, after checking all the boxes for the type truck I have this message came up " there are no fits available " hard to believe you can not put a truck camper on a dual wheel 1 ton long bed pickup truck. Any body have a solution?
  • I think the HD trucks had the same frames right up to 2010, so 2007 or 2007.5, it should use the same kit.
    That said, I have Torklift tiedowns on my 2002 3500 long bed DRW. Should be the same part numbers. Unfortunately I don't have them in my head.
  • Torklift lists multiple tiedown applications for your truck. It's the same as a Chevy.
  • snipped from TL catalog
    2007 (chevy/GMC) is listed under both Classic model (2001-2007) and New body (2007-2010).
    Either has available options for OPs truck. Glitch is possibility to click thru the 'find your fit' guide and get no results, not sure what the combination is.
