My wife and I are new to rving. We have to store our trailer off our property. Our area has variable weather this time of year. We don't want to winterize just yet but we will have intermittent fre...
Depending on your RV, some piping containing water is located in areas where the heat from a furnace or other device won't reach, such as under the unit. That would include at least the fresh water tank drain and the low-point drains. Even if you did leave a heat source on unattended (highly un-recommended), it wouldn't do any good there. Many so-called "four season" trailers have minimal heat ducts to the underside of the trailer, most have none at all -just a thin covering.
