valhalla360
Aug 24, 2022Navigator
So if your SUV is 5400lb, that means the trailer is adding 50% to the weight that it has to stop...plus what other gear/people do you have in the car.
I've had the trailer brakes not work one time and I went slow the 10 miles to get home...it took forever to come to a stop from speed. Not something I would want to repeat.
Also, there is the issue of keeping things in line. If the SUV rear axle starts to slide in a panic stop, the trailer is going to try and push it around into a jacknife. Trailer brakes will try to keep everything in line.
As suggested, see if you can add brakes to the trailer. There's a reason manufacturers provide much higher tow ratings when the trailer has brakes.
44,072 PostsLatest Activity: Aug 23, 2026
