mkirsch
Aug 24, 2022Nomad II
So now we're up to needing a 2500 (3/4 ton) truck to tow a 2700lb trailer?
I see you your 3/4 ton and raise you one diesel dually. Better make that 2700lb trailer a tri-axle, brakes on all axles, while you're at it.
Brakes are a good idea but the point is going to a SMALLER tow vehicle, which the OP can easily do with a 2700lb trailer, if they install some brakes.
44,072 PostsLatest Activity: Aug 23, 2026
