Grit_dog
Aug 24, 2022Trailblazer
JRscooby wrote:valhalla360 wrote:
So if your SUV is 5400lb, that means the trailer is adding 50% to the weight that it has to stop...plus what other gear/people do you have in the car.
I've had the trailer brakes not work one time and I went slow the 10 miles to get home...it took forever to come to a stop from speed. Not something I would want to repeat.
Also, there is the issue of keeping things in line. If the SUV rear axle starts to slide in a panic stop, the trailer is going to try and push it around into a jacknife. Trailer brakes will try to keep everything in line.
As suggested, see if you can add brakes to the trailer. There's a reason manufacturers provide much higher tow ratings when the trailer has brakes.
Rear lock up? You hope. The TW reduces weight on the front, increases on the rear. Plus light vehicles are expected for front to do most of the stopping. (Bigger brakes) So it is much more likely for the front to lock up. Remember when you where a kid, would lock the rear brake on your bicycle and go sliding? Good fun, and only wore out the back tire. If the front wheel ever locked the wear was on knees and elbows.
Now later, ever try to stop on ice, feel front sliding? You have no control over direction.
Now I know your modern ride has anti-lock brakes, will release the brake on the wheels that want to slide. But if that slide is happening because you are stopping more weight than system is designed for, and a smaller percentage of that weight is on front wheels, anti stop brakes. But you can steer into something cheap.
Consider the source Scoob. Heck, you can't even lock up any brakes on virtually any vehicle from the last 20 years.
But, if not having trailer brakes, ONCE, lol, for 10 miles is a memorable event, unless that 10 miles was down Wolf Creek Pass, one should probably reserve comment....
44,072 PostsLatest Activity: Aug 23, 2026
