StirCrazy
Aug 31, 2022Moderator
Fisherman wrote:
Marty
and to add to the confusion for a dealer to sell a trailer in canada if it has a GVW over 2000lbs then it must be sold with break away trailer brakes. this insures all trailers sold in canada met the most strict of provincial requirments.
If you look at the individual provincial requirements, it's still around 3000lbs in some provinces. I just spoke to a trailer shop and when I mentioned BC, his eyes rolled back so far...enough said.
bc is in the middle of all the provences so I don't know why he would roll his eyes. what I was talking about here is the federal sails requirment. if you look you won't find a 2000lb rated trailer sold in canada that doesnt have trailer brakes. unless its old as heck or a home built . you will see lots of 1990lbs trailers out there with out them though haha
here are the actual provincial numbers
Alberta - If gross laden weight of trailer is 909 kg / 2,004 Ibs or over, or if gross trailer weight is over half that of the unit, independent braking system is required.
Not required for trailers with a gross laden weight of not more than 910 kg (2006 Ibs) or trailers with a gross laden weight of less than half of the weight of the towing unit.
Breakaway brakes are required on trailers over 907 kg (2,000 Ibs).
BC - Gross trailer weight of 1,400 kg (3,080 Ibs) or less – Brakes are required if the trailer and its load weigh more than 50% of the licensed weight of the vehicle towing it.
Gross trailer weight of 1,401 kg (3,081 Ibs) to 2,800 kg (6,160 Ibs) – Brakes are required, including a breakaway brake.
Saskatchewan - Any trailer towed behind a motor vehicle with a Gross Vehicle Weight Rating (GVWR) of 1,360 kg (2,999 Ibs) and greater, requires brakes on all axles with a break-away system that will apply the brakes of the trailer in the event it breaks away from the towed vehicle.
Manitoba - every trailer that is attached to a motor vehicle and that has a gross weight in excess of 910 kg (2,006 Ibs), when upon a highway shall be equipped with brakes adequate, when operated in combination with the brakes of the motor vehicle to which it is attached, to stop and hold the motor vehicle and trailer, as the case may be, within the distances prescribed by the law (subsection 8).
Breakaway brakes are required on trailers 907 kg (2,000 Ibs) and over.
Ontario - Trailer or semi-trailer - Every trailer or semi-trailer having a gross weight of 1,360 kilograms (3,000 Ibs) or more shall be equipped with brakes adequate to stop and to hold the vehicle.
Quebec - Independent braking system is required in each weight bearing wheel where gross weight exceeds 1,300 kg (2,867 Ibs). Breakaway brakes are required on all trailers 1,360 kg (3,000 Ibs) and over.
New Brunswick - Independent braking system required where gross weight exceeds 1.5 tons or 1,500 kg (3,308 Ibs).
Nova Scotia - Independent braking system required where gross weight of load and vehicle exceeds 1,800 kg (3,969 Ibs). Breakaway brakes are required on all trailers with a registered weight of over 1,350 kg (2,977 Ibs).
Prince Edward Island - Independent braking system where gross weight exceeds 1,500 kg (3,308) lbs.
Newfoundland / Labrador - Independent braking system needed where gross weight exceeds 4,500 kg (9,923 lbs) or two or more axles are used on the trailer.
Yukon Territory - Independent braking system required if gross weight exceeds 910 kg (2,007 lbs) or one-half of the licensed weight of towing vehicle.
Northwest Territories - Brakes required if gross laden weight of trailer is 1,360 kg (2,999 lbs) or over, or if gross laden weight of trailer exceeds 50% of gross laden weight of towing vehicle.
