tealboy's avatar
tealboy
Unbraked trailer, towing limitations
Hey folks, I’m looking for a new tow vehicle for a rig coming in at 2700 lbs, loaded, per the scale. I decided to trade down to a more modest unibody suv like the highlander, telluride or similar with tow ratings of 5000 lbs.vs my customary Tahoe or sequoia since I tow infrequently (3-4x/year).
However, I discovered something I was unaware of, these vehicles often come with a 1000lb limit when trailers are “Unbraked”. My trailer does not have brakes, seems many in this lower weight class don’t, though some do. My state law requires brakes at 3000lbs.
This discovery caused me to to rethink the mid size suv and go back to the sequoia or a Tahoe. I was shocked to realize the big sequoia with 7500 lbs tow rating is also limited to 1000 lbs Unbraked. The Tahoe is 2000 lbs. The gm line of 1500 series pickups also 2k.
Wow. It seems the manufacturers are providing very conservative figures for Unbraked trailers due to liability so no matter what I pick outside of a 2500 series, I am out of compliance with manufactures recommendations/requirements and potentially subject to liability in an accident even though I’m within state law.
I know this group is far more informed than average people relative to towing but I see tons of smaller to mid size trailers like mine, including many boats, without brakes and suspect most are totally unknowing of these low thresholds bc the manufactures brag about high tow ratings but you need to look much deeper for the Unbraked limits .
I’m not sure what to do now. Thoughts on the subject and your awareness of these vehicle limitations?
  • As long as the trailer axle has the square mounting plate, adding brakes is easy. Depending where you buy, the whole backing plates, brake shoes, magnets and hubs would probably be around $400. Add a few dollars more for the wiring. A whole new axle with brakes included may be around $650.
  • Actually it makes good sense. If you add a 2000 lb trailer to a 8000 lb tow vehicle that is 25% more for the vehicle to stop. Are you willing to follow 25% farther from traffic to ensure you can stop in time?
  • I wonder if putting an axle with brakes , or adding brakes to existing axles would be cheaper/better than buying a new tow truck !
