Butch50 wrote:
Really lloks good but a question are you going to add something to keep the blocks or the slinky support from bouncing out as you drive down the road. Might have to look at something like that myself.
Yep, have 11" x 1/4-20 bolts secured with wing nuts and drilled to accept a hairpin type clip to keep the wing nut from coming loose. Planning on running a small cable through the hairpin clips to keep track of them. A little JB weld on a fender washer keeps it attached to the bolt head so less to juggle and keep track of when taking the blocks out.
