Cewilson11's avatar
Cewilson11
Under cabinet sound system HELP!
We recently sold our camper and got a new to us travel trailer. It has inside and outdoor speakers. The sound system is an under the cabinet system and we want to upgrade to a new system that either has blue tooth capabilities or at least an aux. jack to plug our phones into. Problem is I can't find any systems that are under xab. That include multi zone (a b a&b) and have external speaker jacks to attach to the existing speakers. We really have no place to put an in wall system so need under the cabinet Mount. Any ideas? Thanks!
  • I don't know exactly what system you have...we had a Concertone in our trailer. It gave up and I ordered a Jensen to replace it. I had to cut the area out a little to put the Jensen in. I have outside speakers so I had to do some figuring on the wiring. The Jensen just has A, B and A and B. I ended up having to parallel my speakers. I did make sure I had labeled the out wires so I could then hook up the new ones. Now..I wish that I had gotten a better unit...Jensen doesn't like all my CD's.
  • Could you just build a little wooden box to put it in, and mount that under the cabinet??
  • Most car stereo system are set up for 4 speakers. This will use a "fader" option. What I have done is install an on/off switch for both inside and outside speakers. This way, they can be turned on or off independently without touching the settings on the stereo.
    Check out Crutchfield for options.
